What Linux distribuitions support CFX?
Old   September 21, 2007, 10:19
Default What Linux distribuitions support CFX?
Bayard Morales
Hi there.
I´ve been running CFX under SuSE and Red Hat Linux distributions, but I´m looking for information on running CFX under other distributions.
Does anyone have this kind of experience - like running CFX under Ubunto, etc?
Thanks.
Old   September 28, 2007, 13:05
Default Re: What Linux distribuitions support CFX?
Rui Pereira
As far as I know, Fedora Core 4 supports CFX 10.0, but there is an issue that i want to discuss w you.
CFX actually works with linux FC4, BUT, the mesh cannot be built on CFX mesh of Ansys workbench 10.0.
FC4 supports Ansys workbench 10.0 in FEA analysis and geometry creation/meshing, but once you try to mesh a simple geometry for CFX analysis, follow all the steps, create in design modeler, validate geometry in CFX mesh, mesh surfaces, it refuses to mesh the volume with an error message about nvol3d.exe.
So I have 3 questions that i would like to make to you:
1. Is it possible to perform a CFX analysis "decoupled" from mesh creation in Workbench 10.0 CFX mesher?
(cuz CFX performs flawlessly on the tutorials in CFX install...)
2. Did that particular bug i refered to ever ocured to you in the Red Hat or Suse Distros that you use?
3. Is it possible that the bug is merely an installation/configuration issue and not a basic incompatibility...?
Best regards
Rui Alexandre Pereira
Old   September 28, 2007, 14:19
Bayard Morales
Hi there. I´ll try to help as much as I can.
1. Yes. Actually, I always used Ansys ICEM to create my meshes. You can just import a mesh, I CFX accept meshes created thru many softwares.
2. No, I can´t relate no similar problem.
3. Maybe. Sometimes, the Linux distros just doesn´t have something required by Ansys software. An exemple can be found if you try to run CFX under Open SUSE.
Hope it was helpful. Thanks for your help, good luck.
cfx distributed parallel running problem in linux greatwall CFX 0 August 19, 2011 01:26
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 14:22
PhD using CFX Rui CFX 9 May 28, 2007 06:59
CFX on Linux Ogbeni CFX 14 December 3, 2003 09:25
Beowulf Clusters, Extrem Linux Support Jonas Larsson Main CFD Forum 2 March 31, 1999 01:50
