How to get together plotted results and solid part
Old   September 20, 2007, 08:54
Default How to get together plotted results and solid part
Giuseppe
Hi there, my name is Giuseppe. I've performed a static simulation in CFX to study the flow rate through a simple tee-tube. The original solid part was in SolidWorks. I've imported it in DesignModeler and then I've created the fluid domain, I've defined the boundary conditions in CFX-Pre and ultimately I've run the Solver in CFX-Solver. The solver told me the simulation has completed normally. Right away I've plotted some results( temperature, pressure, velocity) in the fluid domain by means of streamlines, contours and vectors. This is my question: how could I see these results get together to my part since I've only the fluid domain defined in CFX. Is there a rule of thumb to view results in the solid original domain? Thanks in advance. Giuseppe
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
Solid Surface and Fluid Results Plot CK FLOW-3D 2 November 12, 2008 01:32
How to join together CFX results and solid parts Giuseppe CFX 2 October 13, 2007 15:28
Can we add extra solid mesh part to the analsis? Farhath Alam FLUENT 0 December 22, 2006 03:41
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
