October 13, 2022, 06:33 |
How to simulate Water vapor condensation?
MANU P ANAND
Rep Power: 12 |
I want to model and understand the condensation process in high speed flows, for example if i want to study transonic bump, which may create weak shock wave which in turn create non equilibrium condensation.
Medium: Air. 1)How to create material property of air? If I want to vary the relative humidity how should I create material? Do I have to use CCL or CEL? 2) Is MUSCL TVD scheme available in CFX? How can i make it enable? if not what are the other compatible discretization schemes available for CFX? 3)How to include droplet growth model? 4) How to visualize droplet growth? I mean what is the parameter I should enable to make it calculate so that i can post process in CFD post or Tecplot? If you find any related documents to study, please share.... |
October 13, 2022, 09:20 |
#2 | |
Rep Power: 33 |
October 13, 2022, 21:37 |
MANU P ANAND
Rep Power: 12 |
Thank you for the reply. I had checked it in CFX reference guide I have not seen this. I was confused because several journal paper related to high speed flows did not mentioned about what model, I will have to try this.
October 14, 2022, 10:03 |
Rep Power: 33 |
https://journals.sagepub.com/doi/abs...57650917730664
https://www.sciencedirect.com/scienc...510020305692#!
October 14, 2022, 21:13 |
#5 | |
MANU P ANAND
Rep Power: 12 |
Thank you for sharing the reference. |
November 9, 2023, 22:43 |
Alex Ji
Rep Power: 3 |
Hello, I am conducting numerical simulations of non equilibrium condensation. I hope to customize the nucleation rate equation by using the CEL language, but the calculation results are not the same as those of the built-in formula in CFX. Can you give me some advice in this regard? I have posted the specific details on the forum. Thank you very much.
November 10, 2023, 01:47 |
Rep Power: 144 |
You have already asked this question in your other thread: Non-Equilibrium Condensing in CFX
Please do not duplicate post. Please put any comments on this question on the other linked thread.
ccl, cfx, condensation flow, high speed flow |
Need help to Simulate Phase change of Water liquid after mixing with Hot Air Stream | diineshns | FLUENT | 0 | March 17, 2018 07:14 |
How to simulate a hull in Fluent using VOF | dmaz | FLUENT | 11 | August 4, 2015 15:54 |
How to simulate the process of water evaporation by UDF? | qiyang860908 | Fluent UDF and Scheme Programming | 10 | January 9, 2015 14:59 |
which program can be used to simulate to compress water? | arwang | Main CFD Forum | 1 | March 31, 2013 05:20 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
