October 10, 2022, 12:37 |
Quick Animation in steady simulations
Rep Power: 7 |
I have a question about the Quick Animation in CFD Post. If the simulation is steady and if we make a contour plot for a parameter on a plane, we can make a Quick Animation for that contour plot and the distribution of the parameter will be changing during the running of the animation, but how could this happen if the simulation is steady and there are no different time steps to change the frame at each? |
October 17, 2022, 06:10 |
Daniel
Rep Power: 9 |
Did you use the Sweep Animation Method ? If so, in the CFX Post manual this is written:
"The Sweep Animation option provides a means to automatically sweep objects across their defined range to visualize the data throughout the domain. Planes, isosurfaces, turbo surfaces, streamlines, and particle tracks can all be animated with the Quick Animator." So it just sweeps through your domain. |
contour plots, quick animation, steady simulation |
Transient simulation gives worse results than steady state simulation | jgross | CFX | 12 | January 21, 2021 13:21 |
Steady state simpleFOAM crash | Galactus | OpenFOAM Running, Solving & CFD | 12 | August 14, 2019 07:06 |
Quick question on MRF simulations | A-Pop | Main CFD Forum | 1 | August 25, 2012 11:25 |
Differences between steady and transient simulations | egge24 | ANSYS | 2 | April 28, 2012 21:52 |
Psuedo Steady Simulations | Greg Perkins | Main CFD Forum | 0 | October 14, 2000 01:49 |
