June 9, 2020, 10:54 |
#41 |
Rep Power: 33 |
You should be able to compute the mass flow on the boundaries of the domain interface. What do I mean?
An ANSYS CFX domain interface joins two sides, say Side 1 and Side 2. Those sides are represented by boundaries. Usually named as <interface name> Side 1, and <interface name> Side 2 You should be able to monitor massFlow()@<interface name> Side 1 as well as massFlow()@<interface name> Side 2 but you cannot massFlow()@<interface name> For a conservative domain interface, massFlow()@<interface name> is identically 0 by definition. What comes through one side (say >0) has to leave through the other side (<0); therefore, the total sum is 0. It may be non-zero due to discretization details on non-conformal meshes. Hope the above helps,
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum. Last edited by Opaque; June 9, 2020 at 10:55. Reason: missing information |
June 9, 2020, 10:59 |
#42 | |
Rep Power: 33 |
MyAVExpressionX=Density*x I say create an Additional Variable, see Insert menu for details. Once created, - activate the variable in the domain of interest - select algebraic equation - In the additional variable value widget, add you expression: Additional Variable Value = Density*x or Additional Variable Value = MyAVExpressionX - Press Apply, - Add your monitor expression It will work.
Mass flow rate: calculation v/s computation | beguxa | FLUENT | 5 | December 2, 2018 21:02 |
Compressible Flow in Ansys CFX | bcheruk | CFX | 15 | July 6, 2017 06:30 |
in CFX, how to define a inlet condition of feedback control flow rate ? | suihenry | CFX | 12 | May 14, 2009 17:59 |
mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 00:32 |
Mass Flow Rate Calculation | Paul | FLUENT | 9 | March 23, 2002 08:37 |
