inflation layers for hexa mesh using icem cfd |
September 12, 2007, 05:56 |
Hi everyone!
I'm creating a mesh of a pipe using blocking and O-grid methods.I want to create inflation layers near the boundary layer but I can't do it using mesh prism command. Is it because I have hexa mesh or it is just because of the size parameters? Any suggestions? Thanks a lot, I'm quite new to icem cfd. Regards, Apple |
September 12, 2007, 07:17 |
Re: inflation layers for hexa mesh using icem cfd
Since you are doing hexa mesh, you can set the near wall node distance and the strech ratio in the O grid edge itself. This will help you in resolving the wall region well. I am not sure why you are trying for Prism option along with hexa. It is meant for resolving near wall for tetra mesh. Regards Anantha |
September 12, 2007, 11:50 |
It's probably a good idea to go through some of the hexa meshing tutorials to see how to apply the edge parameters to get near-wall spacings for boundary layers and expand the mesh size into the interior.
September 12, 2007, 22:22 |
Thanks Anantha and myron
Thanks guys, I usually use CFX Mesh before and I just started using ICEM. I'll follow your advice guys. Thanks!
Apple |
January 6, 2012, 01:12 |
ICEM tutorials
J. Farooqui
Rep Power: 15 |
plz suggest some good tutorials for simple 3D geometry on ICEM that are available online.
i am not able to follow the tutorials given in ANSYS. |
Loading previously saved mesh in ICEM CFD | user0314 | ANSYS Meshing & Geometry | 1 | September 20, 2011 13:46 |
[ICEM] Problem with volume mesh in ICEM CFD | kolapoasafa | ANSYS Meshing & Geometry | 2 | September 16, 2011 04:54 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
ICEM CFD 5.1 Hex-Tet mesh merging failure | bogesz | CFX | 1 | January 29, 2005 07:46 |
