September 11, 2007, 14:23 |
CFX Transient time step
I need a advice for select a time step for a simulation in a centrifugal pump.Where i begin? What i have that consider for this?
Thanks, Jorge |
September 11, 2007, 17:20 |
Re: CFX Transient time step
To start, try a timestep that is at least 1/20th of the time it takes for one blade passage. The following expressions will return the appropriate time for a rotor with 11 blades at 30,000 RPM with 20 steps per passage
RPM = 30000 [rev/min] Number of Passages = 11 steps per passage = 20 timeStep = 1/RPM/Number of Passages/steps per passage or timeStep = 1/(RPM*Number of Passages*steps per passage) You can then use 'timeStep' to specify the timestep instead of inserting a value, allowing you to change 'steps per passage' as desired. -CycLone |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 05:13 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 06:55 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
AMG versus ICCG | msrinath80 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2006 16:15 |
Small time step and CFX solver crashing | Vanessa | CFX | 2 | June 21, 2006 10:18 |
