question about define speed of rotation and speed of revolution in CFX |
August 28, 2022, 10:10 |
Rep Power: 4 |
Hello, everyone! I have got this question about simulating flow in the bearing. I define the speed of revolution in the bearing domain, and I also need to define the speed of rotation of the ball of the bearing. I insert a new coordinate frame, and its origin is set in the center of the ball. I want to set the frame as a rotating frame, but after that, I can't define the wall velocity of the ball by the new rotating frame to define a relative speed. If I set the frame as stationary, I can define the wall velocity of the ball by the new rotating frame, but the frame is stationary.
And here is my question: if I set the new frame as stationary, will the revolution speed of the bearing domain be added to the ball for I want to define a relative speed of the ball; otherwise, if I set the new frame as a rotating one, how could I define the wall velocity? Thank you very much! |
cfx, coordinate motion, wall velocity |
time depend wall rotation speed | Grigor Nikolov | FLUENT | 0 | October 28, 2015 05:49 |
Fluent rp var to modify rotation speed of a boundary | QBeast | FLUENT | 2 | August 12, 2015 15:58 |
UDF to change Rotation Speed in a MRF simulation | Mike | FLUENT | 3 | September 27, 2011 06:46 |
Why Specify rotation speed? | NTM | FLUENT | 2 | September 12, 2008 05:39 |
rotation speed in the domain | jiaye gan | CFX | 3 | April 5, 2004 08:50 |
