Transient free surface with initial conditions |
August 30, 2007, 17:12 |
I have this problem. I'm trying to simulate a tank with water and air at 6 bar. Suddenly a valve at the bottom is opened and I want to see how the air moves the water through a pipe that is connected to the bottom of the tank. To set the initial conditions I created three domains and I set the volume fractions for each one. When I star the solver I get the following message: floating point exception-overflow. I have made some free surface problems before and I didn't have any problem. What could be wrong? What should I do? Is it possible to fix the initial conditions as I did?
August 30, 2007, 19:31 |
Re: Transient free surface with initial conditions
If the valve and piping are at the bottom of the tank can't you just model the tank as water only with no free surface and just impose a pressure on the top surface? You don't need a multiphase model then and it will be much easier. Glenn Horrocks |
August 31, 2007, 09:50 |
But the one who asked me to do the work wants to know if a "water bullet" can be created with the system. We will have, in the pipe, air, water and air pushing the water. I want to see how this "package of water" flows through the pipe and deforms. And also how could I fix a pressure on top if it would vary with time?
August 31, 2007, 19:33 |
If you want to know the air/water interface then you need multiphase. Have you read the best practises guide in the documentation on multiphase? Glenn Horrocks |
September 3, 2007, 09:54 |
Yes. I have made a simulation without any problem. But in that simulation I had an inlet and an outlet. The only difference here is that I have only an outlet and the initials conditios are a little more complicated(I have also tried with an opening). Now I'm getting the "floating point exception". Thanks in advance.
Compressible Nozzle Flow | sebastian | OpenFOAM Running, Solving & CFD | 14 | September 21, 2016 11:47 |
Velocity blows up suddenly after 30,000+ iterations | lordvon | OpenFOAM Running, Solving & CFD | 15 | October 19, 2015 14:52 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 06:55 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 04:32 |
MRFSimpleFoam amp cyclic patches | david | OpenFOAM Running, Solving & CFD | 36 | October 21, 2008 22:55 |
