Decrease in Entropy
Old   August 30, 2007, 00:52
Default Decrease in Entropy
RAMU MADDI
I am solving Axial turbine blade through cfx. I am using material as steam. When I am checking the static entropy at inlet and exit, i found the inlet entropy is more than the exit entropy which is against physics.Can any one help me in this issue, what could be the problem.
Old   September 3, 2007, 08:51
Default Re: Decrease in Entropy
Dr. V. Kumar
It is not against physics. Since you have inlet/outlet it is an open system and thermodynamics says that entropy of an isolated system can not decrease.
What is happening in between inlet and outlet will be an indicator that why entropy is decrease/increased e.g. heat loss or friction etc.
Old   September 4, 2007, 09:55
CycLone
This is exactly what you should expect from a steam turbine. Just look as the H-S diagram for the cycle.
-CycLone
Old   September 4, 2007, 10:09
CycLone
...I should add that the entropy of the stage should increase, but it is expected to see a drop in entropy through the rotor.
-CycLone
Negative Entropy Antimony FLUENT 0 February 10, 2009 08:57
Entropy jump across shocks Dave Main CFD Forum 8 March 12, 2008 11:21
about entropy stability prapanj Main CFD Forum 5 February 16, 2007 19:24
Entropy condition and ENO scheme Question Man. Main CFD Forum 5 January 17, 2003 08:10
decrease in residual order and it's influence michel Main CFD Forum 2 July 22, 2002 19:16
