pollutant dispersion
Old   August 25, 2007, 09:53
Default pollutant dispersion
Andy
hi
i'm simulating a dispersion of pollutants on atmosphere. the pollutants are emited from a source as an additional variabele, which are different from the air. But in the CFX-pre, there is no any option for setting the characteristic of the addition variable(pollutants).
i wonder how to set the characteristic of the additon variable like the density,buoyancy etl.
Thank you very much!
by the way ,i want to make friend who are also interested in this field.
Old   August 26, 2007, 19:41
Default Re: pollutant dispersion
The additional variable approach does not use density, buoyancy etc. The only parameter is dissipation. If you want to include density and buoyancy effects you will need to use a multicomponent multiphase model, or some other multiphase model.
Pollutant dispersion in the environment alberto OpenFOAM Running, Solving & CFD 24 November 29, 2014 14:31
Stability problem due to turbulent dispersion force in a subcooled boiling model Edy OpenFOAM 7 August 10, 2011 13:00
Turbulent Dispersion for Coal Combustion gravis CFX 2 March 24, 2010 00:56
Simulation of pollutant dispersion in a city George Siemens 1 June 27, 2007 05:26
Question on Dispersion Mike Marcu FLUENT 2 September 14, 2005 20:53
