how to import the curve into blade gen
Old   August 21, 2007, 23:37
Default how to import the curve into blade gen
fadly
let say I design curve using certain NACA spec in CATIA.how can I import that curve into blade gen??I'm quite new in blade gen and turbogrid...i try to explore it now. thanx fo helping me
Old   August 22, 2007, 08:09
Default Re: how to import the curve into blade gen
Pankaj
Export your blade profile from catia to iges or ibl format & import it in bladegen using new data import wizard with by selecting respective curves for hub,shroud,blade layers.
Regards, Pankaj.
Old   August 23, 2007, 05:27
fadly
Thank you.i found that function.it reads my file but still confusing to select the curve.for your information, my fan blade design is about 3 metres (blade-to-blade) including hub. how can i select the shroud??any idea..
blade gen tutorials Ramesh.K CFX 5 November 8, 2014 15:33
Is blade Gen the only tool to quickly alter blade geometry?? Discovery69 Main CFD Forum 0 December 2, 2010 11:25
HELP ME!!! I cannot import blade in autogrid! Nicola Fidelity CFD 2 February 1, 2008 04:38
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
