Linking issues User Fortran
Old   August 20, 2007, 09:47
Default Linking issues User Fortran
Anil
When I try to link user fortran example files, the MS linker does not recognize any CEL functions. I am using CFX-11 on a WINNT-AMD-64 machine with a INTEL compiler. If I comment the CEL functions there is no problem. It is as if the CFX library is not being linked/imported?
Does anybody have any ideas?
Thanks in advance Anil Microsoft (R) Incremental Linker Version 8.00.50727.42 Copyright (C) Microsoft Corporation. All rights reserved.
-out:.\winnt-amd64\\myfunc.dll -dll -implib:.\winnt-amd64\\myfunc.lib winnt-amd64\\backstep.o "C:\Program Files\ANSYS Inc\v110\CFX\lib\winnt-amd64\solver-pvm.lib"
Creating library .\winnt-amd64\\myfunc.lib and object .\winnt-amd64\\myfunc.e xp backstep.o : error LNK2019: unresolved external symbol _PEEKCS@40 referenced in function _USER_INPUT backstep.o : error LNK2019: unresolved external symbol _MESAGE@16 referenced in function _USER_INPUT backstep.o : error LNK2019: unresolved external symbol _PSHDIR@24 referenced in function _USER_INPUT backstep.o : error LNK2019: unresolved external symbol _CHGDIR@24 referenced in function _USER_INPUT backstep.o : error LNK2019: unresolved external symbol _MAKDAT@40 referenced in function _USER_INPUT backstep.o : error LNK2019: unresolved external symbol _POKEI@36 referenced in f unction _USER_INPUT backstep.o : error LNK2019: unresolved external symbol _POPDIR@16 referenced in function _USER_INPUT backstep.o : error LNK2019: unresolved external symbol _CFXSTP@8 referenced in f unction _USER_INPUT_TABLE backstep.o : error LNK2019: unresolved external symbol _SET_A_0@8 referenced in function _USER_UPROFILE backstep.o : error LNK2019: unresolved external symbol _PEEKI@36 referenced in f unction _USER_UPROFILE backstep.o : error LNK2019: unresolved external symbol _LOCDAT@40 referenced in function _USER_UPROFILE backstep.o : error LNK2019: unresolved external symbol _CFROMI@12 referenced in function _USER_PRINT_PROFILE backstep.o : error LNK2019: unresolved external symbol _CFROMR@12 referenced in function _USER_PRINT_PROFILE .\winnt-amd64\\myfunc.dll : fatal error LNK1120: 13 unresolved externals An error has occurred in cfx5mkext:
C:\Program Files (x86)\Intel\Compiler\Fortran\9.1\Ia32\Bin\ifort exited with return code 96.
Old   August 23, 2007, 17:55
Default Re: Linking issues User Fortran
Stumpy
Are you using cfx5mkext to compile your fortran?
Old   August 24, 2007, 21:41
Anil
Yes I don't have visual c++ toolkit but have MS visual studio, I am wondering if that is the problem.
Old   February 24, 2017, 22:48
FeiTeng
tengf689 is on a distinguished road
I met the same problem as you. Have you solved the problem?
tengf689 is offline   Reply With Quote
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
user routine, user funcion, or fortran compile effect on the memroy? princeps11 CFX 1 May 13, 2009 19:37
User fortran routines, DEBUG AND OUTPUT Bloshchitsyn Vladimir CFX 5 October 29, 2007 02:31
OpenFOAM with Cygwin kitchener OpenFOAM Installation 6 April 25, 2006 00:09
CFX5 and user FORTRAN Worth CFX 9 December 25, 2003 02:43
