August 20, 2007, 03:48 |
friction losses
hii,
how do you calculate the friction losses in a Diffuser flow using CFX? I would like to separate out the frictional losses from the other losses that occurs in a diffuser. thanks.. |
August 20, 2007, 09:19 |
Re: friction losses
Depends on exactly what you are trying to get. Some possibilities are to look at the wall shear stress or total pressure of the fluid or otherwise you can do a momentum balance from the inlet to outlet. Glenn Horrocks |
caculation of friction factor | Dilip | Main CFD Forum | 9 | February 23, 2016 06:00 |
Openfoam friction coefficient differences. | Peter88 | OpenFOAM Post-Processing | 0 | February 8, 2011 11:07 |
buoyancy - losses estimation through total pressure | clrsgfn | CFX | 4 | November 10, 2010 12:05 |
friction & windage losses prediction - help needed | alex | CFX | 0 | August 28, 2006 10:51 |
Compute Skin friction coef by hand | Francois | FLUENT | 1 | February 10, 2006 07:21 |
