Prevent turbulence generation in and transport through a porous zone |
July 21, 2022, 06:19 |
Stuart
Rep Power: 26 |
I'm modelling a internal airflow system which contains a filter (incompressible flow with the SST model). The filter is modelled macroscopically as a subdomain with experimental derived permeability and loss coefficient in the streamwise direction and the default streamwise multiplier for the traverse directions. The porous zone pressure drop is as expected from the experimental data.
In reality the narrow, random pathways through the filter will prevent upstream eddies passing through and then downstream. Also the turbulence generated in the filter will not happen as locally the flow is laminar. So just downstream of the porous zone the k-omega values must 'start again'. In CFX I guess a sink expression is needed (with a total coefficient). Anyone have a clue what expression I could use? In Fluent a laminar zone or enforced source value can be set. But I'm not sure how to set k and omega to 0 in the porous zone. Thanks |
July 21, 2022, 06:40 |
Gert-Jan
Rep Power: 28 |
I would just give it a try with several values. In principle, you just want get rid of the turbulence, so the lower the better, I would say.
Alternatively, I would try to switch off the option "Constant Domain Physics" under Options>General>Beta Options. This allows you to run turbulent in domain 1, and laminar in domain 2. This works pretty if these are separated by a wall. Not sure if it works when they are connected and the fluid flows from turbulent to laminar, but you could give it a try. |
July 21, 2022, 07:24 |
Stuart
Rep Power: 26 |
Not sure yet if I can just enter very low numbers into CFX-Pre Subdomain area.
It will take some trying but I want to stop turbulence from the upstream fluid domain transporting through the porous domain, whilst also stopping new turbulence generation in the porous domain (the Fluent laminar zone option only does the latter). |
July 21, 2022, 07:32 |
Gert-Jan
Rep Power: 28 |
Shouldn't you set a huge Eddy Dissipation Rate?
July 21, 2022, 11:15 |
Rep Power: 33 |
Have you thought about setting Eddy Viscosity = 0 in the porous domain? The equation is solved, but no diffusion and no production.
July 21, 2022, 20:00 |
Rep Power: 144 |
Yet another approach to consider is to use the turbulence transition model, with specified intermittency. This way you can explicitly set the laminar and turbulent bits. So set the foam as laminar and the flow domain as turbulent.
August 11, 2022, 06:34 |
Stuart
Rep Power: 26 |
August 11, 2022, 10:19 |
Rep Power: 33 |
In the panel for Domain/Fluid Models/Turbulence/Advanced Turbulence Control
August 15, 2022, 02:54 |
#9 | |
Stuart
Rep Power: 26 |
Ideally, there would be a option in the subdomain Equation Sources to do this. |
August 15, 2022, 03:14 |
#10 |
Rep Power: 144 |
I cannot see how you can use Opaque's suggestion wither. Hopefully he can explain how to do it.
So can't you just use a source term to set k=0 in the filter regions? Note you don't want to set omega =0, that might lead to problems. I would just let omega go to any value it wanted.
August 15, 2022, 06:55 |
#11 |
Stuart
Rep Power: 26 |
I am giving the TKE source term a try now within the subdomain, based on the general momentum source term equation of -C(k - kspec), where kspec is zero and C is the CFX recommended value of 1x10^5.
Glenn, interesting that you say to leave omega alone. I have CFX running now and I did set it as a source term also: -C(omega). I'll see what it looks like. Thanks. |
November 15, 2022, 03:33 |
#12 | |
Stuart
Rep Power: 26 |
Taking this one step further, but I cannot get it to work yet. In my CFX model I have 1 domain and I use a subdomain for each porous volume to input the directional loss model values. How can I extend the above expression for multiple porous volume subdomains, since I have only one domain? I tried using the AND operator in the expression for each subdomain e.g. if(inside()@Porous1==1&&inside()@Porous2==1,1.e-18[Pa s],Eddy Viscosity) but CFX-Solver Manager gave an error code which I could not resolve (see image) and also tried using the OR operator but that also failed. |
November 15, 2022, 04:46 |
#13 |
Rep Power: 144 |
I should have mentioned this a long time ago, but do you need to do any of this? If you just model everything with a turbulence model which degenerates nicely to laminar flow (like SST or k-w, k-eps does not) then the turbulence will naturally fade to zero in the laminar bits and it will be very close to the laminar solution in those regions.
I have done several tests of SST turbulence models in benchmark laminar flows and found that the error is tiny in many cases (a fraction of a percent). So I would try just running the whole thing with the SST model. Do a benchmark simulation to check, maybe just of the filter element to check the SST model does degenerate acceptably close to a laminar solution - I bet you will it is close enough for what you are doing, and does not require weeks of your development and debugging time.
