Post processing information in particular zones
Old   August 9, 2007, 11:15
Default Post processing information in particular zones
Juan Catelén
Hello everybody. I'm having a problem. I want to calculate the average velocity in a specific part of a piece that has a complicate geometry. If I use a plane I can't set the bonds I want and I'm taking some zones that I don't want to include in the calculation. What should I do? Is the only possibility to put a surface in the geometry before mesh creation? I'll be waiting for your help. Bye.
Old   August 9, 2007, 13:07
Default Re: Post processing information in particular zone
Gui
I see what you mean, I had the same problem to calculate the mass flow at certain locations of my domain. I spent a lot of time trying to use the perfect bounds of my plane to not include other geometry. Finally it worked, but I don't think it's very practical to use planes and I don't understand, there must be another options but I don't know wich so that's why I'm joining your post.
Old   August 9, 2007, 15:47
Robin
Can you describe more precisely what defines the bounds you wish to use? Is it a geometric location, a function of the results, etc. There are some solutions that may not be immediately obvious (which I have posted before). The answer depends on what exactly you are trying to do.
-Robin
Old   August 10, 2007, 03:41
Dr. Flow Squad
Yes- it would be nice to have a "until boundaries is met" option with the planes cutting multiple domains. But the trick is to create a contour plot and colour it with a coordinate. Then create a new user surface based on that contour, and do the math on that plane. Try it out, you may have to change the numbers of contours on your plot and change the range of the scale as well, but it works! -Dr. Flow Squad http://tinyurl.com/2gkjh8
Ansys Post Processing Brian_P Main CFD Forum 0 March 4, 2010 17:05
Hidden patch for post processing in OF? ericnutsch OpenFOAM 0 March 1, 2010 02:28
looking for a post processing s/w han Main CFD Forum 0 May 9, 2001 23:44
PRE and POST processing package Astrid Barros Main CFD Forum 6 November 16, 2000 11:31
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 21:51
