how do you check values at different iteration
Old   August 6, 2007, 11:38
Default how do you check values at different iteration
Gui
I wanted to know if you ran a simulation and never stopped it until you click stop, if it is possible to check the values at different iterations to see if the solution is converged
Old   August 6, 2007, 11:57
Default Re: how do you check values at different iteration
hammam
you can moitor your varibles at cfx pre to see the convergence history of your variables while the simulation is running in cfx solver
Old   August 6, 2007, 13:00
Gui
yes I know that but I want to check the variable values and profiles at several iterations and not see the convergence history
Old   August 7, 2007, 06:48
Li
You can backup your simulation results at different iterations in specifying output. Goodluck!
Regards Li
Old   August 7, 2007, 14:33
Gui
oh yeah I forgot that I did this. But how do you open the backup files? Is it the same as a post ?
Old   August 8, 2007, 12:33
Li
I think so, buy you can just try it. If it doesn't work, try to change the .bak file to .res file.
how to increase "Newton Pressure Iteration Limit" kus CFX 9 April 21, 2013 02:54
iteration in solver wlt_1985 FLUENT 0 September 21, 2011 05:48
Monitor Points values in CFX-Solver Silmaril CFX 1 March 10, 2011 09:48
Getting solution values per iteration Joao Bettencourt CFX 3 October 4, 2006 11:24
Creating, loop or iteration using expression edito Jan CFX 3 July 28, 2003 12:01
