aspect ratio vs. y+
Old   August 5, 2007, 09:31
Default aspect ratio vs. y+
hammam
Hi all
iam simulating 2d airfoil using c-grid topology , i want to trade off between y+ and aspect ratio , i use sst & ( Gamma-Theta) trnsition model which needs y+<1 , i meshed my domain by hex mesh using pre-mesh>edge meshing parameter tool.
i decrease the y+ by decreasing the edge spacing from the airfoil and i increase the number of nodes by using low edge ratio at the airfoil surface.
when i used a hyperbolic mesh with spacing 1e-4 it gives me a maximum aspect ratio of about 17000 .
and the convergence was unstable.
so what is the solution for that problem?
& what is the acceptable value for aspect ratio to use?
thanks Hammam
Old   August 6, 2007, 10:19
Default Re: aspect ratio vs. y+
johnny
did you try running in double precision?
Old   August 6, 2007, 11:27
hammam
hello
excuse me would you please explain what is double precision, and how to use it?
regards
Old   August 6, 2007, 11:41
Gui
double precision is a more precise calculation (the values are represented with more digits).
you can get it before starting you run in the solver, where you can specify initial value file, you can click on "show advanced control" and there you can specify double precision
pressure eq. "converges" after few time steps maddalena OpenFOAM Running, Solving & CFD 69 July 21, 2011 08:42
[ICEM] Mesh along axis for a wedge gives elements with extreme aspect ratio sangrampp ANSYS Meshing & Geometry 0 November 17, 2010 07:57
High Aspect Ratio elements Flavio CFX 2 November 24, 2006 13:01
does aspect ratio affect analysis mahesh Main CFD Forum 2 October 10, 2005 10:12
Aspect Ratio at high turbulent and swirled flows zago FLUENT 0 May 19, 2004 03:37
