Importing Solidworks Assembly
Old   August 4, 2007, 16:23
Default Importing Solidworks Assembly
rmc
I am attempting a dynamic analysis on a small rope bridge I modeled in Solidworks. I would like to analyze the whole assembly in ANSYS but am having problems transferring the file.
When I imported the assembly into ANSYS I used all the default settings (no defeaturing, merge coincident keypts, create solid if applicable, delete small areas). The result I get is an unassembled stack of parts, and the solid parts seem to be saved as areas not volumes (I can replot keypoints, lines, and areas, but no volumes).
I have tried to create a volume by selecting areas, and this works well. However, when I try to move the volume into its proper position I get the following error:
"Keypoint (#) is attached to line (#), which is attached to an entity that cannot be moved. Command VGEN unable to be executed with the move option and this set of entities."
I have tried saving the parts individually as iges files and opening them in ANSYS but once I have two parts imported the program either shuts down or I get the same error message as before.
Is there some way to import a Solidworks assembly into ANSYS without getting these problems, or is there something I am doing wrong? I am new to this program so any insight would be much appreciated.
Thanks in advance!
Old   August 5, 2007, 07:10
Default Re: Importing Solidworks Assembly
pankaj
hi ! Try to export your solidworks assembly into parasolid file, this can be imported in design modeller and then to ansys.
hope it works.
Pankaj.
Old   August 17, 2007, 04:27
Pradeep
I just posted a reply on the other site http://www.topix.com/forum/com/anss/TS71RMJOTSUQIR9IS
Old   September 30, 2014, 11:34
Igna's Avatar
Ignacio
Igna is on a distinguished road
Hey pankaj, I had the same problem and I solved it in that way that you said. Thanks a lot!
Greetings,
Ignacio
Igna is offline   Reply With Quote
Importing SolidWorks Model DIRECTLY into openfoam bgood44 OpenFOAM 9 January 20, 2020 07:47
Importing Rhinoceros 3d model to SolidWorks george85 FloEFD, FloWorks & FloTHERM 21 March 5, 2014 06:19
Importing Solidworks part into ICEM CFD MetalSupremacist FLUENT 0 October 8, 2010 18:46
Problem importing solidworks to gambit holyo ANSYS Meshing & Geometry 3 April 16, 2010 06:16
Importing geometry from solidworks John FLUENT 5 April 4, 2008 07:27
