How can I implement multistep reactions in CFX?
Old   July 30, 2007, 09:48
Default How can I implement multistep reactions in CFX?
Harry
I found some reduced multiple-step reactions for methane-air mixture. And I want to import it into CFX. But I do not know how can I achieve it.
Does anyone can help me?
Thanks-Harry
Old   July 30, 2007, 13:14
Default Re: How can I implement multistep reactions in CFX
opaque
Dear Harry,
Have you looked at how ANSYS CFX does the multiple step reactions? Try using one of the provided mechanisms work, and copy/paste from there.
Opaque
Old   July 31, 2007, 10:20
Harry
Thanks, Opaque
I find several reaction mechanisms in CFX installation folder. Without NO formation, there are:
Methane Air WD1--one step;
Methane Air WD2--two steps;
Methane Air WGS--five steps;
Methane Air FLL STP
Right? Is there any limitation when using them?
If I have a reaction model, with several species and several reactions, how can I use it in CFX?
Thank you!
Old   July 31, 2007, 11:58
opaque
Dear Harry,
There is no chemical reaction import mechanism in CFX; therefore, you must type the CCL using the supplied mechanism as a template.
Look into your CFX installation directory for the file
etc/reactions-extra/REACTIONS-standard.ccl
The syntax of how to write your own mechanism is described.
Opaque
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Reactions in CFX brajh11 CFX 2 October 19, 2009 16:07
little CFX test mauz ANSYS 0 May 16, 2009 06:27
Electronics Enclosure Analysis with CFX Simulation Engineer CFX 1 April 22, 2009 12:08
v2-f turbulence model in CFX? flga CFX 14 November 23, 2006 07:12
