Composite regions
Old   July 28, 2007, 17:10
Default Composite regions
Gui
In order to specify the same boundary condition on multiple windows, I created a composite region including all of the windows. If I want to have a pressure of 20000 Pa on each of the windows, should I specify an opening pressure boundary condition with value 20000 Pa or 20000*(number of windows) ? Cause it depends if CFX consider this composite region as a single region or if it consider the windows independently. Same question if you specify a mass flow.
Thank you
Old   July 30, 2007, 10:46
Default Re: Composite regions
Robin
First of all, you don't necessarily need to create a composite region, just select all of your regions when you create the boundary condition.
Pressure doesn't scale with area, so the answer is NO for a pressure inlet boundary condition. If you specify the mass flow rate, it should be the total mass flow rate, which will be applied as a CONSTANT FLUX, so this will only work divide the mass flow evenly if you have the same area on each window. If the area varies and you want a constant mass flow through each you will need separate boundary conditions.
Regards, Robin
Splitting regions king_steve STAR-CCM+ 1 September 27, 2010 13:48
Connect 2 Regions Marc_r OpenFOAM 2 April 19, 2010 14:27
Composite Engine Valve Project cortez505 FLUENT 1 November 18, 2009 05:02
how to define different regions in icem ? Hammam CFX 3 July 9, 2007 13:56
refinement causes composite regions, how to solve? Harry CFX 4 December 8, 2004 06:13
