June 5, 2022, 11:50 |
Replace the rho(T,P) with rho(h,P) method.
Zhiyuan Liu
Rep Power: 8 |
By default, RGP file of CFX uses temperature and pressure as the EoS basic variables to calculate enthalpy and entropy. However, the calculation result of the energy equation is indeed enthalpy. This is unfavorable to the accuracy and robustness of the calculation. Is there any possibility of replacing the rho(T,P) with rho(h,P) method.
I found that Fluent could replace the temperature-based energy equation with an enthalpy-based formulation. Moreover, density, viscosity, diffusion coefficient etc.. could be expressed as functions of pressure and specific enthalpy. |
June 6, 2022, 09:36 |
#2 | |
Rep Power: 33 |
In the general CFD literature, the most common solution variable for the compressible (ideal and real gas) form of the energy equation is Total Enthalpy. It is not Temperature, nor Static Enthalpy.
June 6, 2022, 21:44 |
#3 | |
Zhiyuan Liu
Rep Power: 8 |
Based on the mass/momentum/energy equations, CFX can obtain local velocity/pressure/enthalpy (h_tot-V^2/2). However, CFX needs to first calculate h (T, P) and s (T, P) according to EoS rho (T, P) + Cp (T, P), and then obtain T= (h, P), rho (h, P) and s (h, P). This means that CFX needs to perform a reverse lookup on the physical property table, which may lead to deviations in physical properties. Especially when the physical properties are sensitive to temperature and pressure. |
June 7, 2022, 09:55 |
Rep Power: 33 |
I see what you are referring to; however, there is confusion on where the errors are coming from.
Let us assume the thermodynamic state is analytical and non-linear, i.e. no table lookup. That means we can compute the sequence you describe - calculate h (T, P) and s (T, P) - according to EoS rho (T, P) and Cp (T, P), - and then obtain T= (h, P) exactly. Corrrect? A root-finder must be used since the equations are likely non-linear (say Newton method). The above proves there is no need for an alternative formulation. The source of error is not in the formulation but in the quality of how obtain the remaining thermodynamic quantities. When CFX uses property tables, there is an inherent assumption that some error is introduced, and that error comes in from the creation of those tables. If you want to reduce the error, you generate better tables. The formulation is correct already. If you change the formulation, you still have to do a reverse lookup, either analytical or via numerical interpolation. You will be moving the "concern" to another variable, but fixing nothing.
June 8, 2022, 18:28 |
Erik
Rep Power: 23 |
Any general advice on "Generating better tables"?
More data points? But can you make them too large where truncation with too fine of points becomes a problem? |
rgp |
Inaccurate gradient results from continuous Adjoint method | Yminjo | SU2 | 1 | January 11, 2014 23:08 |
multiphaseEulerFoam: method mag(...) withing method solveAlphase() | maybee | OpenFOAM Programming & Development | 0 | December 21, 2013 11:13 |
Help about the preconditioner in gmres method | Dan Gao | Main CFD Forum | 3 | July 5, 2008 02:18 |
About flowfield-dependent variation(FDV) method? | Jinwon | Main CFD Forum | 1 | December 4, 2007 22:13 |
tidal flow simulation using finite volume method | Jason Qiu | Main CFD Forum | 0 | October 20, 2002 03:34 |
