Analysis of Centrifugal compressor
Old   May 31, 2022, 08:02
Smile Analysis of Centrifugal compressor
Mnabeel is on a distinguished road
Greeting everyone
I am currently working on simulation of a centrifugal compressor in CFX.
I have CAD model of compressor but i am unable to import it to turbogrid for meshing. It has spitter blades too and i am very stuck as i don't know how to import the geometry in turbogrid.
I have watched many tutorials but i am not getting any break through.
Mnabeel is offline   Reply With Quote
Old   November 14, 2022, 03:51
MANU P ANAND
manupanand is on a distinguished road
Originally Posted by Mnabeel View Post
Greeting everyone
Explain detail. What module you use to import to turbo grid.? Are you importing from design modeler, Did you define flow path?
manupanand is offline   Reply With Quote
Old   November 16, 2022, 19:32
QC
Mohsen_mtl is on a distinguished road
I did it before using siemens NX. I hope the attached picture helps you.
Mohsen_mtl is offline   Reply With Quote
Old   November 17, 2022, 03:53
Daniel
zacko is on a distinguished road
Did you use the TurboGrid Point based method with the hub, shroud and blade curve files?
If not, you could extract points for hub and shroud as well as all your blade profiles (along the blade span) inside your 3D-CAD model and write them into a curve file. This is mentioned in the tutorials as well.
zacko is offline   Reply With Quote
Old   November 17, 2022, 03:55
Daniel
Also, if you get any errors when you import your model (or your curve files), please, provide them as well here, so we better can get to the cause of your problem.
Old   January 4, 2023, 22:24
MANU P ANAND
https://www.youtube.com/watch?v=vezubXUEyYk
See this video this can help you
centrifugal compressor, compressor blade
Transient Analysis Of axial compressor rohit_turbo CFX 4 May 20, 2016 03:39
Possible to simulate a working Centrifugal Compressor for jet engine on OpenFOAM? fazlur OpenFOAM 1 August 21, 2013 05:30
Centrifugal compressor mass flow error Attesz CFX 18 May 27, 2012 11:17
The Onset of Surge in a centrifugal compressor Suzzn CFX 4 December 19, 2009 09:49
centrifugal compressor impeller with splitter blad deepesh nanda Main CFD Forum 2 October 18, 2004 12:13
