July 25, 2007, 13:45 |
smooth DTF surface
is there an easy way to smooth a DTF (triangulated) surface in ICEM? Right now I import 3 points per triangle, and the curved parts of the surface have edges. I thought about using quadratic elements for the triangles and smoothing by choosing the inner points to smooth the overall surface. Is there a geometry smoothing feature in ICEM. Do you know some other program to do this? Thanks in advance, N.R. |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
smooth DTF surface | N.R. | Main CFD Forum | 1 | July 25, 2007 13:43 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
