Question about copying a single-passage result to the full-passage |
Rep Power: 4 ![]() |
Hello, everyone. I am doing a fluid-thermal-solid interaction project, linking the CFX model to the static structural model. I compute the solid body temperature in CFX by conjugate-heat transfer, and I import the body temperature to the solid in the static structural model to calculate thermal stress and deformation.
And the problem is that I compute a single passage result; for example, I calculate the temperature of a turbine with 21 blades, and I want the whole turbine's body temperature so I can obtain the entire turbine's thermal stress and deformation . Can anybody please help me copy the single-passage result of the CFX to the whole passage? Thank you so much! |
Rep Power: 33 ![]() |
May I ask why you would want to replicate around 360?
Can you solve the thermal-stress problem with periodic boundaries? It has to be 21 times faster, and less memory
Thank you for your reply. Let me describe this problem more precisely. I want to solve a whole turbine's thermal stress and thermal deformation problem. The period of the turbine rotor is 21, while the period of the turbine stator is 27. I split the turbine stator into two parts; one is the turbine stator forward, and the other is the turbine casing behind. If I use single-passage, I don't know how to transfer the stress and deformation from the casing to the stator; besides, I find out that there seems to be no way to solve the problem of different periods in one model, the static-structural model of the Ansys workbench. And that's why I want to solve the problem in a whole passage.
fsi mapping, multi-passage |
[ICEM] question about Blocking a full scale vertical axis wind turbine | mohsen razavi | ANSYS Meshing & Geometry | 0 | February 24, 2015 06:11 |
Question about transient result output | Anna Tian | CFX | 10 | July 5, 2013 11:32 |
Question about Graphic in result | TommyLui | FLUENT | 0 | September 8, 2011 00:58 |
Simulation of a single passage and volute | Suzzn | CFX | 1 | January 5, 2010 07:05 |
Single phase result file for multiphase simulation | Kushagra | CFX | 2 | July 8, 2008 21:14 |
