July 19, 2007, 13:58 |
Negative pressure
Hi folk,
I'm simulating a valve with a big pressure (200 Bar)drop through a small passage with a incompressible fluid the process converges but in the results I found some big areas with negative pressure: total and static. can I consider the results correct? Or what can I consider correct? for Example if I use a Inlet with mass flow and an Outlet whith atmosferic pressure, can I consider the pressure drop correct? Thanks |
July 19, 2007, 15:57 |
Re: Negative pressure
Hi Luca,
Since your fluid is incompressible the equation of state (i.e. fluid properties) are not dependant on pressure and therefore the solution is not dependant on pressure level (i.e. you will get the same solution regardless of what your reference pressure is, as long as the relative pressures remain the same). A negative pressure may be the result of liquid in tension but may also lead to cavitation in your real system. Note that if you include cavitation effects you solution WILL become pressure level dependant. Regards, Robin |
July 20, 2007, 03:27 |
Hi Robin,
thanks for your exhaustive answer. but I have to do an other question, in this kind of analysis I study forces that are applaied on surface where there are negative and positive pressure and the last purpose of this analysis is to balance the force. so are results (force) correct or not? and for this kind of analysis is better SST or a K-e? Thanks |
July 20, 2007, 16:38 |
The results are fine for this purpose but make sure that if the part has surfaces that are not exposed to the fluid (i.e. the outside of a pipe), you need to include the pressure on the outside. You'll get this if the domain reference pressure is equal to the outside pressure since the "Pressure" in CFX would then represent the gauge pressure.
Whether to run SST or k-e depends on many factors. In general I would go with SST since the results will be similar for the most part, but SST will also do a better job resolving separation. The SST prediction will also improve as you resolve more of the boundary layer, whereas k-e will do so only to a limit. This is a loaded topic, so I recommend reviewing the doc, literature and other posts on this forum to learn more. Regards, Robin |
July 24, 2007, 11:32 |
Hi Robin,
Thanks for your help, your explanation is very clear. But I have an other question, if a have a negative pressure on a surface where I have to check the force, CFX uses the negative pressure to calculate the force or not? Thanks in advance. Luca |
July 24, 2007, 12:11 |
Yes, CFX will use the negative pressure.
July 25, 2007, 05:08 |
Thanks for your answer, but there is a method to calculate the force without negative pressure? Because in surface where I have to balance the force I have a part with negative pressure and in the same surface other parts with Positive pressure. I would set the minimum pressure (to calculate the force) to 1 Atm that is also the reference pressure. Thank in advance. Luca |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 12:35 |
seeking for help about a room with negative pressure | mengyue1 | FLUENT | 0 | November 26, 2009 07:40 |
High pressure in rhopSonicFoam results in negative pressure | shangzung | OpenFOAM | 0 | November 5, 2009 04:24 |
negative pressure in cfx | flar.t | CFX | 1 | December 19, 2006 00:20 |
negative pressure | mAx | FLUENT | 0 | January 25, 2006 15:31 |
