Chemical reaction between gas and solid through a porous media
Old   May 10, 2022, 13:52
Default Chemical reaction between gas and solid through a porous media
YoannRbt is on a distinguished road
Hi everyone,
I want to model a gas flow through a porous media with a chemical reaction. The chemical reaction is : 2HF + CaCO3 = CaF2 + CO2 +H2O where the gas is the HF and the CaCO3 (solid state) is the porous media.
I've looked through the tutorials and tried to adapt the chapter 15. I've computed the different source terms for my reaction. The subdomain in my porous media is defined.
The model gives no errors but the results are not good. I can only visualize the HF masse fraction but it does not seem to be affected by the reaction, other mass fraction are equal to 0. In short, the reacton does not occur.
Any help would be greatly appreciated!
YoannRbt is offline   Reply With Quote
Old   May 10, 2022, 16:48
Opaque will become famous soon enough
Would you mind sharing what those source terms look like?
Did you do it via CEL, or using built-in reaction modeling?
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Old   May 10, 2022, 16:56
I did it via the CEL
I've copied the CEL files of the tutorial (Chapter 15) and changed it with the values of my reaction. I added expression for each product of the reaction.
The CCL file is joined with the reply
Old   May 10, 2022, 17:30
I am a bit confused by your expressions.
CaCO3 is the solid matrix; therefore, the concept of mass fraction, CaCO3.mf does not exists. Mass Fractions are variables for the multicomponent phase.
I am surprised you did not get an error for such usage.
Also, you seem to have taken the Eddy Dissipation route for the combustion, not the finite rate chemistry mechanism. Not certain Eddy Dissipation makes sense for such a reaction.
Old   May 10, 2022, 17:48
Hmm, I was afraid of that but I tried it anyway, did not work.
I guess a second error balanced for the first..
In the tutorial, the Eddy break up formulation is used, it doesn't seem to be a combustion on this case, I thought I could also use it.
I will try the finite rate chemistry model and hope it will work.
Thanks for the advice
Old   May 17, 2022, 17:13
I tried to use the finite rate chemistry model for the same chemical reaction: 2HF + CaCO3 = CaF2 + CO2 +H2O
I've defined the chemical reaction as follows
LIBRARY:
&replace REACTION: Reaction 1
Object Origin = User
Option = Single Step
COMBUSTION MODEL:
Chemical Timescale = 1.37E-4 [s]
Extinction Temperature = 900 [K]
Option = Finite Rate Chemistry
END
FORWARD REACTION RATE:
Option = Expression
Reaction Rate = -7.72e-11 [mol m^-3 s^-1]
END
PRODUCTS:
Materials List = CO2,CaF2,H2O
Option = Child Materials
CHILD MATERIAL: CO2
Option = Stoichiometric
Stoichiometric Coefficient = 1.0
END
CHILD MATERIAL: CaF2
END
CHILD MATERIAL: H2O
END
END
REACTANTS:
Materials List = CaCO3,HF
CHILD MATERIAL: CaCO3
END
CHILD MATERIAL: HF
Stoichiometric Coefficient = 2
END
END
END
END
The material (mixture reaction) is defined (reactant, product, and air).
Fluid model: air on constraint, others on transport equation.
I'm still not able to see the product of reaction (mf = 0)...
Also, the CaCO3 in the porous domain is supposed to be transformed into CaF2. How can I define the change of material in the porous domain during the reaction process?
Thanks
Solver for gas flow through porous media including heat transfer in OpenFOAM v3.0+ Germilly OpenFOAM Running, Solving & CFD 30 May 10, 2024 08:37
gas diffusion through porous solid media flo777 FLUENT 1 February 15, 2024 11:53
How to define a reaction between a porous solid (not a catalyst) and gas yijecho FLUENT 4 December 1, 2020 00:13
porous media reaction with inflow gas Yuting CFX 0 August 14, 2016 21:58
porous media with chemical reaction Arvind Phate FLUENT 2 July 18, 2005 14:52
