Pressure Gradient BC
Old   July 12, 2007, 14:16
Default Pressure Gradient BC
selim
Hi, I have a rectangular shape and perform a heat transfer CFD computation.
I want to be the pressure gradients (PX,PY) be zwro at the inlet and also have a velocity BC. Is this possible in CFX,CFD? Also for the outlet I want to make the pressure gradients vanish.How can I do it in CFX 11?
Another question: At the top I have symetry BC Does pressure gradients vanish in these case?
Simply I dont want any pressure gradient at the boundries of Rectangular Shape.(inlet,outlet etc..)
Any suggestions
Thanks, Selim
Old   July 16, 2007, 11:08
Default Re: Pressure Gradient BC
Robin
Set a Static Pressure inlet and use the Zero Gradient option.
Old   July 16, 2007, 14:26
Robin
Sorry, I should have payed closer attention to your question. It is not possible to specify both the pressure and the velocity, you need to pick one. Specifying both would be overspecifying the problem and would not be physically realistic.
-Robin
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 07:52
Inputting pressure gradient in Fluent Josyula FLUENT 2 December 23, 2009 08:26
Atmospheric pressure gradient Luc3er FLUENT 1 October 30, 2009 07:46
Hydrostatic pressure gradient Craig Finch (Finch) OpenFOAM Running, Solving & CFD 10 March 1, 2007 00:02
Flat plate with pressure gradient Sheila Main CFD Forum 3 September 24, 2005 14:58
