steady state solution
Old   July 9, 2007, 10:13
Default steady state solution
cfxdude
Does steady state solution depends on your initial guess?
cfxdude
Old   July 9, 2007, 10:35
Default Re: steady state solution
Gert-Jan
A complete converged solution (i.e. constant values in monitoring points, imbalances=0, RMS residuals < 1e-6) should not depend on initial guess.
Gert-Jan
Old   July 9, 2007, 10:57
cfxdude
What you are saying is that If 1e-5 < RMS residuals (pressure and velocities) <1e-4 and 1e-6 < RMS residual (k-e turb) < 1e-3 is not a steady state solution, or the solution depends on the initial guess?
In my case the velocity of the monitored point is fluctuating between 0.25 - 0.35 m/s (11000 iteration), but the volume average velocity is constant. which one is the correct steady state indication.
Thanks.
cfxdude
Old   July 9, 2007, 11:31
Gert-Jan
When your monitoring values are fluctuating, you won't have a steady state situation. Looks like your problem is time dependent.
Gert-Jan
Old   July 9, 2007, 11:38
cfxdude
So constant volume average velocity is not the steady state indication.
Is there any book or paper about these, I am looking for some thing written.
Thanks for your time.
A.A.
Old   July 9, 2007, 19:20
For a small number of situations the steady state solution does depend on the initial guess. I have seen some flows were the Coanda effect caused a jet to stick to one wall or the other depending, then settle down to a steady state solution. Which wall the jet stuck to depended on the initial guess.
In general, however, a fully converged solution is independent of initial guess.
Old   July 9, 2007, 19:28
Italy
If the velocity of the monitored point is fluctuating between 0.25 - 0.35 m/s after 11000 iteration, try to increase gradually the timescale. In this way you should obtain a non fluctuating velocity value.
Probably now you are reading some fluctuations of your domain; increasing the timescale works as a filter for this numerical fluctuations.
Bye
Alberto
Old   July 10, 2007, 06:43
Helge
Numerical fluctuations? You may damp out physical fluctuations by numerics. If you increase the time step you may stabilize the solution but you will not get a fully converged (grid independant and time step independant) solution.
I agree with Gert-Jan and Glenn
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Steady State Vs Transient answers Kushagra CFX 25 July 23, 2017 04:20
Solver for transonic flow? Martin Hegedus OpenFOAM Running, Solving & CFD 22 December 16, 2015 05:59
Steady State 2 phase problem fivos FLUENT 0 April 27, 2009 17:34
regarding steady state discrete phase calculations hajszan_gyula FLUENT 1 February 28, 2006 02:32
