ICEM --> FLUENT, boundary conditions
FLUENT, boundary conditions " border="0" /> ICEM --> FLUENT, boundary conditions
Old   July 9, 2007, 08:59
Default ICEM --> FLUENT, boundary conditions
Tobias
Hello!
My problem is the following:
I´m generating a 2D-mesh with ICEM and assign a name and a boundary condition (wall, axis, pressure-inlet, etc.) to each edge. Then I export the mesh to Fluent. But sometimes all names and bc of the edge are successfully imported into Fluent, but sometimes not. In the latter case the only edge repectively boundary condition which gets imported is "part_1_edge".
It seems that sometimes I´m doing everything right, but sometimes I don´t. But unfortunately I can´t see any differences in my work between both cases...
Can anyone help me?
Thank you very much.
Best regards,
Tobi
Old   July 9, 2007, 11:35
Default Re: ICEM --> FLUENT, boundary conditions
myron
For a 2D mesh, make sure the LINE elements are associated with the correct part names. LINE elements must completely bound the mesh for 2D.
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
non reflective boundary conditions for incompresible flow Pascal_doran OpenFOAM Programming & Development 16 August 25, 2015 06:35
rotational periodic boundary conditions in ICEM user0314 ANSYS Meshing & Geometry 1 June 21, 2011 02:57
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Boundary conditions in Fluent 4.5 Arturo Ortiz FLUENT 0 January 25, 2001 18:52
