Backup results in steady simulation
Old   July 9, 2007, 06:39
Default Backup results in steady simulation
Li
Hi guys! I am doing simulation with CFX in cluster, so I didn't get the results files finally when it didn't arrive at the convergence criteria or the walltime wasn't enough long. In help documents, it is said you can save results with setting backup results file in output control and I did set a backup result file with the name of Backup resulsts1 and set the interation list with 1000, 4000, 6000. But I didn't get any backup results files? Would you tell me what's wrong with my settings? Thank you very much!
With kind regards Li
Under-relaxation for steady state simulation in CFX Chander CFX 7 May 1, 2014 13:44
Transient Simulation. Is antialiasing of the results possible? Darren Leong ANSYS 0 July 19, 2011 00:39
Backup mdef simulation Daniel Leite Oliveira CFX 0 July 8, 2011 13:35
how to map results from steady state run to tranient case? phsieh2005 OpenFOAM Running, Solving & CFD 2 November 7, 2010 07:20
exemple of simulation results in reactive flow GACEM_hatem Phoenics 0 June 6, 2001 15:13
