Negative volume in mesh motion
Old   July 7, 2007, 10:02
Default Negative volume in mesh motion
skarp
Dear Friends
I was solving a moving mesh problem like check valve.y negative volume occurs reason?
ERROR #002100012 has occurred in subroutine cVolSec. Message: A negative ELEMENT volume has been detected. This is a fatal error and execution will be terminated. The location of the first negative volume is reported below. Volume : -0.4107E-13 | Location : ( -0.35156E-02, 0.36065E-01, -0.49511E-03)
Old   July 7, 2007, 12:16
Default Re: Negative volume in mesh motion
JH
Hello. That error is very common when you try to deform a domain. There is no easy answer. The first thing you may do is to identify the small mesh elements in your domain with volume negative (they are so small that were reverse like a t-shirt that you just take off...) try to use planes and volume regions (with "draw lines" active) to locate such elements. Once you know approximately the location, you may have to modify the mesh stiffness equation in order to get a better node displacement when deforming the mesh and check the new elements status (try a mesh stiffness equation: 1 [m^3 s^-1]/Wall Distance; or 1 [m^5 s^-1]/Volume of Finite Volumes). You also may check the surface displacement after deformation, it may be doing a impossible movement. I hope this lines gives you an idea. Good Luck.
Old   July 9, 2007, 01:24
skarp
Thanks dude
Can u tell me why negative volume occurs ?
Old   July 11, 2007, 00:53
skarp
I have find out the reason for negative volume
F=ma m-mass of the ball,a=acceleration of ball F=force of the flow.
since i have specified only the force of flow and no other opposing force like spring or gravity force.My ball is hiting the wall in first iteration itself and stops saying negative volume.In post the wall bulges.
Can anyone tell how to stop the ball before it reaches the wall.
Old   July 11, 2007, 19:31
Negative volume errors occur when an element is turned inside out due to the mesh motion.
You need to check your motion equations and possibly use a finer timestep.
Old   July 12, 2007, 00:51
SKARP
Hi
My problems is I have flow force only and no other force opposing the flow force.
I want to stop the ball before the ball goes and hit the wall. Is there any eqn to resist the motion of the ball only to a certain displacement.
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Dynamic mesh, negative volume, help! vboris FLUENT 0 February 23, 2011 18:19
engrid: Internal volume mesh becoming coarser during boundayr layer addition Arnoldinho OpenFOAM 1 January 22, 2011 05:31
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
