how to define different regions in icem ?
Old   July 7, 2007, 09:40
Default how to define different regions in icem ?
Hammam
hi guys
in icem i have a planar surface (2d)and i extruded the mesh of this surface by one element but it only extrude the mesh not the curves of the surface and i want to define different regions like inlet,outlet,top bot to solve in cfx but i have only volume side top
side is a composite region consists of the different regions so how to define this regions seperately to apply the boundary conditions to it in cfx ?
n.b: i have read all the previous posts and i didnot get it
thanks
Old   July 9, 2007, 11:36
Default Re: how to define different regions in icem ?
myron
You must select the surface elements and place them into the desired parts after the extrusion process.
Old   July 9, 2007, 12:38
Hammam
but selection of the surface elemnts is not possible because surfaces is not defined
Old   July 9, 2007, 13:56
Hammam
thank you i made it
thanks
How to define multiple fluid regions in icem user0314 ANSYS Meshing & Geometry 6 June 2, 2020 01:28
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 10:23
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 11:19
