Euler-Euler simulation of evaporating spray
Old   July 4, 2007, 09:49
Default Euler-Euler simulation of evaporating spray
Xavier Ponticq
Hi All,
In my research project I'm dealing with evaporating sprays and want to compare Euler-Euler simulations to Euler-Lagrange simulations with CFX 11.0 (Euler-Lagrange simulations work fine). I wish to simulate the evaporation of a liquid spray in a gaz mixture composed of air and the liquid vapor. But I've some troubles in the set-up of mass transfert for evaporation.
I followed the modeling advice of CFX help by adding a dummy material to the liquid phase, but the results especially concerning the volume fraction are not satisfactory. Actually, using a dummy material as the constraint in the liquid phase implies that this dummy material appears from nowhere in the simulation as the pure liquid is evaporating. Thus I get a liquid volume fraction that is defined everywhere in the domain and not only where lies the liquid spray.
Adding a dummy material allows to use Component pairs models to describe the evaporation process. Without this dummy material I can't see how to use an evaporation model except by providing a value for the mass transfert coefficient. So, if you have any ideas....
Regards
Sofware for spray simulation Joe Main CFD Forum 3 December 10, 2007 17:07
spray simulation CFD IƱigo Iparragirre Main CFD Forum 0 November 6, 2006 09:34
Fire simulation using FDS from NIST Jens Main CFD Forum 1 January 22, 2004 02:53
Kiva3V to simulation open-air LOW-pressure spray? G.Thibaudeau Main CFD Forum 0 March 14, 2000 08:44
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
