June 28, 2007, 06:08 |
Double Boundary
Can I in CFX create a boundary that has double settings? For a multiphase application I would like to have the continuous air phase to treat a specific surface as wall, but for the dispersed solid particles the surface should be an outlet. Can it be done?
June 28, 2007, 07:05 |
Re: Double Boundary
Turn off the particles as they strike that particular wall?
June 28, 2007, 08:12 |
Re: Double Boundary
It's an Euler-Euler approach. Two "fluids" and no particles.
June 28, 2007, 08:50 |
Re: Double Boundary
Hi Dr Flow Squad!
U can try the following suggestion. In Boundary details of an outlet define Degassing Condition in the option of Mass and Momentum,So that it will allow only dispersed phase to go out and it will restrict continuous phase to leave. Hope it will work. Sameer |
June 28, 2007, 08:59 |
Re: Double Boundary
Degassing conditon. Doesn't it work the other way around? Letting only the continuous phase to leave?
June 28, 2007, 09:04 |
Re: Double Boundary
"degassing" boundary condition. Commonly used for chem reactor studies.
June 28, 2007, 12:17 |
Re: Double Boundary
No, the degassing condition will allow the dispersed phase to leave. However, it is only applicable to "degassing", i.e. bubbles rising and leaving the top. I don't recall the details but it has something to do with the hydrostatic pressure.
What is it you are trying to model? There may be another approach. Regards, Robin |
June 29, 2007, 02:30 |
Re: Double Boundary
I'm simply modelling a good old fashion cyclone. the loading is rather high, and I also want to determine the separation efficiency due to loading so I'm using a Euler-Euler approach instead of particles. But I want all my gas to exit at the top of the cyclone, whereas "particles" that touch the bottom surface should be collected.
June 29, 2007, 12:07 |
Re: Double Boundary
#9 |
What physically prevents gas from exiting the bottom?
July 7, 2007, 16:54 |
Re: Double Boundary
#10 |
a "snail". -
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 06:58 |
ReactingFoam Error | sahm | OpenFOAM | 4 | August 20, 2010 16:22 |
transient simulation of a rotating rectangle | icesniffer | CFX | 1 | August 8, 2009 08:25 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 02:54 |
