cfx pressure-fsi simulation
Old   June 24, 2007, 06:59
Default cfx pressure-fsi simulation
Pankaj
As described in the new tutorial for FSI simulation of a centrifugal compressor,we have to export CFX pressure to Ansys to study its effect on the impeller.
But what values it exports? Whether we can calculate this in CFX-Post? Or is there any other method to calculate load on the Shaft/Impeller due to fluid?
Any references are appreciated.
Thanks in advance.
Old   June 27, 2007, 14:56
Default Re: cfx pressure-fsi simulation
hayate
hello
i did the same some weeks ago... just make the flow analysis in cfx and then import the pressure load in ansys and thats it.... the code imports all the pressure by sellecting the fases (in the stuctural enviroment) and apply cfx load by choosing the .res file.
best regards hayate
Old   July 11, 2007, 17:21
Default FSI problem..
murat al
Hi, I need help about my research paper.I am studying on blood flow through arteries and I have to simulate the flow and the vessel deformation due to flow..I can simulate the flow but can not couple it with the wall since its physics is different. How can I solve this problem could any of you help me?
Thanks in advance..
murat
Setting Pressure Boundary Conditions in ANSYS CFX Pre saisanthoshm88 CFX 21 February 22, 2017 17:50
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
the pressure coefficient vs angle in CFX?? Jwolf CFX 1 December 14, 2012 08:31
CFX thermo-fluid 2D simulation problems maryliz CFX 6 November 1, 2011 00:26
total pressure in CFX Atit Koonsrisuk CFX 0 January 1, 2005 06:46
