torque calculations
Old   June 21, 2007, 05:50
Default torque calculations
Mechstud
Hi ..
I am working on a simulation of a crop harvesting machine and I want to draw a contour plot of the torque acting on the blade due to fluid. For this I need magnitude of the torque acting on different points of the blade surface.
I used the torque function in CFX post..
torque_z@Rot Blade 1
But this function calculates the total magnitude of the torque acting on the whole blade ..not on discrete infinitesimal points of the blade..please help me to calculate torque on various points of the blade.
Thanks in advance
Mechstud
Old   June 21, 2007, 19:44
Default Re: torque calculations
You could write a CEL function which takes the torque component out of the pressure and wall shear variables, and does a cross product with the rotation axis.
Or you could just do contour plots of pressure and/or wall shear on the blade. No need for CEL functions then.
Old   June 22, 2007, 03:40
Mechstud
Thank you very much Glenn...
Although I have also figured out the solution to this problem 2 hurs later I posted this topic.
I defined variable which calculate torque on a point using forces in x and y direction multiplying with y and x respectively.
and then doing vector addition.
..Well in your solution ..what do you mean by wall shear variables ??..I am a bit new to CFX ..
Thanks a lot for your help once again
Best Wishes ...Mechstud
Old   June 24, 2007, 22:50
Default What is wall shear?
Fluid transfers momentum to a surface by two means. The first is by pressure and the second is by friction, that is shear in the fluid boundary layer. In CFX they are expressed as two separate variables, pressure and wall shear.
Old   June 26, 2007, 09:53
Default Re: What is wall shear?
Mechstud
thanx....its all clear now...
mechstud
Torque calculation of 2D VAWT Wind Turbine Anonymized_JL1 FLUENT 14 September 26, 2013 04:35
Torque Calculation SAH2006 FLUENT 0 September 3, 2010 17:59
Torque definition Yali CFX 2 January 7, 2008 04:13
about use macro to compute torque in TASCflow lancy CFX 0 June 10, 2003 07:19
Torque calculations. J. Keays CFX 21 July 12, 2001 10:03
