Total pressure Inlet vs opening pres. and Dirn
Old   March 7, 2022, 20:23
Default Total pressure Inlet vs opening pres. and Dirn
Jin Seok Lee
jins9158 is on a distinguished road
I have some question
I am analysisng about ventilation system
Dress room has dryer and dryer just can operate about internal air cleaning
We wanted to ventilate (external air cleaning) So, we thoght that it is able to ventilate by using ventilation system where is toilet
But this method has a problem.
Actually, The ventilation system where is toilet can operate "120[cmh]" in 'strong mode'
If we use toilet's ventilation system to ventilate dress room, ventilation performance is likely to be reduced.
So I interpreted it as the following steps:
1. I interpreted just "ventialtion system in toilet" for comparison with experimental values. And I got 119 [cmh].
2. I interpreted "ventilation + dryer". I used "inlet condition is inlet total pressure" and "outlet condition is outlet mass" to use initial condition.
[dryer not work, just ventilaton work]
3. I again interpreted to get mass's result of outlet.
I used "inlet conditon is Opening press. and Dirn" and "outlet condition is Average static pressure". I monitored outlet surface to see mass
[I used "Opening press. and Dirn" about Inlet condition instead of "Inlet total pressure" because of warning massage that Inlet is blocked]
4. final result was "26[cmh]
When I analyzed, I thought that the result is not realistic because Del P just is "30 [Pa]".
I think that The flow rate has been reduced by 10 times, but the pressure difference is too small
So, I have doubts about flow condtion.
The dress room is closed, but the opening pressure condition makes it an open condition.
So, I thought It could generate difference of results
Do you agree?
After analyzing once, when the analysis results are used as initial values, can the results be different in inlet total pressure and opening pressure?
I am so confused. So I want to get advice
http://drive.google.com/uc?export=vi...3Q2_xS3qd-0Tow
jins9158 is offline   Reply With Quote
Puzzle encountered when using opening B.C. for calculation domain Soll CFX 5 July 24, 2017 19:49
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
opening pressure for entrainment Tilman CFX 3 February 10, 2006 05:09
