June 18, 2007, 08:06 |
1-way FSI Setting
I am trying to Uni-directional(1-way) FSI simulatin with ANSYS Multiphysics V.11. Rather than using Ansys classics, I am using Ansys Simulation(in Workbench) and CFX. What I want to know is the optimal settings of the number of stagger iteration and number of coeffieient loops.
In FEA analysis, Contact analysi is perfomed with "Static Structural analysis" with total 100 load steps. In CFX, for each fluid-solid interface, "/Boundary details/mesh mothon/send to ansys" is set to "None" for 1-way FSI, and ANSYS fileds are solved before CFX (/Solver control/external coupling/Solution sequence Control) Then, in CFX, is it nessary that Max iterations number(max. stgger iteration) (/Solver control/External coupling/Coupling step control) is greater than 1 ? Because any data are not sent to ANSYS, it may be sufficient to solver Ansys 1 times and more coefficient loops are nessary for CFX computation in my thought. ( So, max stagger iteration =1 ) In CFX(/Sover control/External coupling/Coupling data transfer control),what's the meaning of Under relaxtion factor, and does it affect the Maximum number of stagger iteration? Regards |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
BCs in an FSI simulation of a flexble pipe | vivekcfd | OpenFOAM | 10 | January 8, 2010 05:14 |
fsi | sun | Siemens | 8 | January 20, 2009 00:17 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 05:08 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
