modeling a pump as momentum source
Old   June 5, 2007, 13:51
Default modeling a pump as momentum source
Priscila
I need to model a pump as a momentum source, but analysing at CFX-Post my pump generates momentum in all directions. It's wrong and I don't know my mistakes.
Tks
Priscila
Old   June 5, 2007, 13:52
Default Re: modeling a pump as momentum source
Priscila
I'm needing sugestions to fix the problem!!
Tks!!
Old   June 5, 2007, 16:42
Gert-Jan
How do you define your momentum source? I would suggest to use cartesian coordinates to define the x,y,z direction of the source. Use 0 for the directions that no momentum is needed.
Gert-Jan
www.bunova.nl
Old   June 5, 2007, 16:59
Priscila
Yep! I did it! I used values for x and y direction and 0 for the other one. So, I don't have idea where is the problem and how to fix it. Can be on the geometry or mesh? I guess not...
Old   June 6, 2007, 11:08
Gert-Jan
I would set 1 momentum and use two zero's.......
Momentum source coefficient and convergence meh CFX 9 October 12, 2020 09:37
momentum source term zwdi FLUENT 14 June 27, 2017 16:40
Momentum source calculation kavitagangisetti FLUENT 0 June 19, 2010 15:29
momentum source in half-cylindrical null objects Noel Phoenics 1 December 16, 2008 06:51
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 04:43
