Condensation of steam in a pipe
Old   June 5, 2007, 11:18
Default Condensation of steam in a pipe
Arijit Ganguli
dear all,
i am arijit from india. i am trying to solve the problem of condensation of steam in a pipe. To start with i have taken steam at the inlet and water at the outlet. half the pipe fills with water and half with steam when an unsteady run was done while for a steady state run no water formation was seen. the pipe length is 50mm in which initial steam of 5mm has been initialized. Thermal Phase change model is used for interphase mass transfer. Zero resistance is given to the continuous fluid and Fluid resistance to the dispersed fluid.i will be obliged if someone can give some clue how to go about with this problem so that i can validate the heat transfer.
thankz a lot in advance arijit
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 07:52
superheated wet steam (avoid condensation in a nozzle) Ralf Schmidt Main CFD Forum 1 August 12, 2009 17:18
superheated wet steam (avoid condensation in a nozzle) Ralf Schmidt FLUENT 0 August 11, 2009 12:55
Multipahse steam condensation BN SIMLOO Siemens 1 September 9, 2004 11:11
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
