about expression
Old   June 5, 2007, 11:12
Default about expression
Jason
Hi,all In the Inlet table,I choose to set "Static pressure".Now I want use an expression, the pressure=15000*t, t is time. How should I set the unit? I has tried many time and it doesn't work. Please do me a favor. Thanks in advance. Jason
Old   June 5, 2007, 11:20
Default Re: about expression
Jason
If just set like this: Inlet pressure=15000*t,the warning come out as followed: Expression resolves to invalid units ('s') in value set for parameter 'Relative Pressure' in object '/FLOW/DOMAINomain 1/BOUNDARY:inlet/BOUNDARY CONDITIONS/MASS AND MOMENTUM'. Expected units: 'kg m^-1 s^-2'.
Old   June 5, 2007, 11:21
Gert-Jan
Pressure has to be in Pa. t is in [s]. So your constant 15000 has to be [Pa/s]. How difficult can it be?
Gert-Jan
www.bunova.nl
Old   June 7, 2007, 05:15
Dr Flow Squad
I Agree!
Or another way of doing it: 15000 [Pa] * t/1[s] -Dr Flow Squad
Problem About Running Fluent In Linux mitra FLUENT 18 June 20, 2019 03:11
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
Lift, Drag Vs time chart,calculations Jamesd69climber CFX 8 February 17, 2005 18:23
Creating, loop or iteration using expression edito Jan CFX 3 July 28, 2003 12:01
