January 13, 2022, 03:41 |
CEL or UDF?
Rep Power: 4 |
I want to modify the turbulence model in CFX, more simply, just want to change some turbulence model parameters. can CEL reach the target? or we must use UDF? This is my fist call for help.Thanks.
January 13, 2022, 06:54 |
Rep Power: 144 |
CFX lets you adjust all the turbulence model parameters in CFX-pre. But whether it will do what you want depends on what you want to do.
cel, turbulence model, udf |
udf for one dimensional linear motion based on force | maccheese | Fluent UDF and Scheme Programming | 2 | September 1, 2019 03:18 |
Save output of udf in another udf! | JuanJoMex | FLUENT | 0 | February 8, 2018 13:43 |
UDF Compilation Error - Loading Library - COMMON Problem! Help! | robtheslob | Fluent UDF and Scheme Programming | 8 | July 24, 2015 01:53 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 23:14 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 05:01 |
