How to red a Gambit mesh with Ansys CFX 10.0
Old   May 29, 2007, 10:14
Default How to red a Gambit mesh with Ansys CFX 10.0
jpsegura
Hi Colleagues:
I want to know how to read a mesh generated by Gambit into Ansys CFX 10.0. Do I have to save the mesh in Gambit with some kind of special extension? wich one? Thanks again
Juan Pablo Segura
Old   May 29, 2007, 10:55
Default Re: How to red a Gambit mesh with Ansys CFX 10.0
opaque
Dear Juan Pablo,
You can export the Gambit mesh into a PATRAN neutral file, or CGNS file..
Better yet.. If you use ANSYS CFX 11.0, you should be able to import a Fluent .msh file directly into CFX-Pre.
Opaque
Old   May 30, 2007, 05:39
zhu
you may export Fluent mesh, then use ICEM read it, last, export cfx mesh.
Old   May 31, 2007, 14:18
Default Re: The whole method
Omer
Here is all you need to do.
You can read the .msh from Gambit to FLUENT. Then you need to initialise it. Then save it a PATRAN neutral file. Directly readable with all regions in CFX.
Old   June 11, 2007, 12:44
Li Rong
Maybe you can export Gambit mesh into Fluent mesh file first, then import it to Flunet software, after that just export to CGNS file, finally it can be read into cfx-pre directly. Good luck!
Li
Old   June 12, 2007, 03:20
Scorpion
No need to do all such long procedures. There is very simple way of doing it.
1. First select solver "Ansys" 2. Then define boundary conditions as "node" 3. Export your "mesh" from export submenu. 4. Your mesh will be exported with extension "*.cdb" 5. Now in CFX-pre while importing mesh select the "Mesh format" as "Ansys" and import the "*.cdb" file created in step 4. 6. Now you can work with it.
Try it & let me know how is it!
Regards
Scorpion
importing mesh from Gambit and other software to ansys workbench mortazavi ANSYS Meshing & Geometry 5 June 6, 2011 12:09
mesh missing after export in gambit morteza08 Main CFD Forum 0 July 23, 2010 03:19
gambit mesh to cfx Hossam CFX 1 November 9, 2008 12:39
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 02:10
Ansys WB 10 2-D mesh for CFX Foti R. CFX 1 December 6, 2006 00:44
