Tracer analysis in CFX with non-Newtonian fluid
Old   December 17, 2021, 08:35
Question Tracer analysis in CFX with non-Newtonian fluid
Isar Charmchi
Isar.charmchi is on a distinguished road
Hi CFXers,
I want to do the tracer test in ANSYS-CFX version 2021R2.
I implement my viscosity as CEL and the CFX-pre give me the following error:
Parameter 'Kinematic Diffusivity' in object '/FLOW:Flow Analysis 1/DOMAINefault Domain/FLUID MODELS/ADDITIONAL VARIABLE:Tracer' has been assigned an expression that references the following unavailable variables: sstrnr
I know that I have to insert my transient result in the CFX-pre as a user function and use them to initialize my velocity and pressure? Am I correct? If yes, I am not sure in transient stats I have to output which parameter? Also, I was thinking if I just output the shear strain rate in transient stats and then export it from postprocessing and input it as a user function in CFX-pre of NY tracer simulation is it not enough?
Would you please clarify for me the issue?
Thanks in advance for your help!
Isar.charmchi is offline   Reply With Quote
Old   December 18, 2021, 04:56
The error states you are setting the kinematic diffusivity of an additional variable. This is not the viscosity. Did you intend to do this? If you want to set the viscosity then you should set the viscosity (obviously).
I do not understand your paragraph starting with "I know that I have to ....". You do not need to use a transient result to set initial conditions for velocity and pressure, you can do it directly. This is covered in the CFX tutorial examples. Have you done the tutorial examples? That covers basic stuff like this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   January 5, 2022, 07:17
Isar Charmchi
Thanks Glenn.
Yes, I am trying to set kinematic viscosity for non-Newtonian fluid that is dependent on shear strain rate of fluid as kinematic viscosity is equal to (viscosity/density). Viscosity of the fluid is changing according to the shear strain rate and while I am trying to set the kinematic viscosity of my tracer I receive error that sstrnr that is the shear strain rate of each cell of the domain is unkown. I would like to know how can I solve the problem?
I am well aware that before running the case you can give the residual file as initial condition for your simulation. but I cannot proceed with this error. I have to give the initial condition or information regarding the sstrnr in CFX-pre.
Thank you in advance!
Old   January 5, 2022, 18:00
Please attach your CCL file.
tracer
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Flat plate analysis in cfx hamed.majeed CFX 14 February 4, 2015 08:07
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Pump Cavitation Analysis in ANSYS CFX techCAE CFX 6 July 3, 2013 07:37
