Filling a tank or pipe
Old   May 22, 2007, 20:06
Default Filling a tank or pipe
stu
A simple scenario, I wish to fill a tank or pipe with water, say I have a pipe that is 10 cm diam, 100 cm long that is standing on its end. I have the following BC's 1 inlet, 1 wall, 1 outlet or opening.
Initially the pipe is filled with air and then I start to fil it from the inlet at the bottom at say 1 cm/sec. How do I setup the physics of this simply problem?
I know that it is a multiphase problem and I use volume fractions, initially the domain is 100% air and 0% water. The inlet BC becomes water at 1cm/sec at 100% vf and air at 0 cm/s 0% vf. The outlet or opening only lets air out, air 100% vf, water 0% vf. And I only have the 1 domain. I can use the KE turb model. I have setup the two fluids as continuous fluids, not dispersed fluids.
What else and I missing?
I want to be able to view the density change as the water moves up the pipe, simple plane with density contour plotted.
For some reason I am having problems trying to get this example to work.
Transient analysis total time 10 sec, time steps 0.1 secs. High resolution (double?) backward euler.
Could someone give me guidance or post a the text based input file that gives the physics of this kind of problem.
Thanks Stu
Old   May 23, 2007, 09:23
Default Re: Filling a tank or pipe
Gert-Jan
Questions:
1) What is your initial guess?
2) I would start with laminar.
3) How does your grid look like? I hope you are using a hex mesh. If not you will get a lot of smearing due to tet elements that are not parallel with your free surface.
4) do you use the free surface sharpening?
5) I would not use two continuous phases. With 1 cm/s mixing is not likely, the way you have set this up.
Gert-Jan
Old   May 23, 2007, 22:20
stu
Thanks for your response
In a further problem I am doing, very similar but different shape ( it is a tank) I am using laminar.
Point 5, " I would not use two continuous phases. With 1 cm/s mixing is not likely, the way you have set this up." If I basically want to view the pipe filling up with water and 'pumping / pushing' the air out, I thought this would be 2 phase. If the tank is initially filled with air vf=1, and then water (vf=1) is pumped in, how can I do this without using 2 continuous fluids? I might be missing something, please feel to point me in the right direction.
Thanks Stu
Old   May 24, 2007, 19:23
Gert-Jan
I mean that you should use the homogeneous model (with free surface model). Then you will have one velocity field and a massfraction for water. This implies less equation and less run time. Indeed both phases are continuous.
I meant that you shouldn't use a heterogeneous model with two continuous phases for this problem as the phases will be completely demixed.
Gert-Jan
www.bunova.nl
[DesignModeler] DesignModeler Pipe within pipe shields ANSYS Meshing & Geometry 13 November 25, 2018 23:14
Filling Tank with Water leff CFX 7 August 21, 2017 08:47
Gas discharge from tank to tank through a pipe Arno FLUENT 4 December 28, 2010 10:52
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
