May 22, 2007, 17:47 |
Outflow in a pool
I need some help with this: I have a pool, with two inlets and two outlets. I know the mass flow at each inlet. I need to find the mass flow at each outlet. The pool is outdoor. My boundary conditions are mass flow at inlet, and static pressure at outlet (reference pressure: 0 bar, relative pressure: 1 bar, so I get atmospheric pressure). Is this OK? I'm making some mistake? Or it is more realistic if I use Average Static Pressure? Thanks for your help.
May 22, 2007, 19:17 |
Re: Outflow in a pool
I think this is OK. But I do not know the situation downstream the outlets. Isn't there something limiting the flow?
Tip: Use a free slip wall for the topsurface. Gert-Jan www.bunova.nl |
May 23, 2007, 09:21 |
Thank you very much for your answer and for the tip. About the situation downstream the outlets, there is nothing limiting the flow. The pool is discharging to an atmospheric tank.
Outflow boundary Control Volume SIMPLE Help !!! | Mizerable | Main CFD Forum | 4 | August 22, 2011 14:00 |
HELP!: swimming pool flow problem | Tee | FLUENT | 1 | September 8, 2005 09:29 |
HELP!:CFD modelling using FLUENT in swimming pool | Tee | Main CFD Forum | 0 | September 7, 2005 21:48 |
mass flux correction at outflow boundaries | Subhra Datta | Main CFD Forum | 2 | November 24, 2003 14:11 |
Outflow Bocos | Romuald Skoda | Main CFD Forum | 3 | August 6, 1999 04:08 |
