May 21, 2007, 08:54 |
recirc tank, inlet outlet conditions
If I have a simple tank which I take water out via a pump and then pump it back into the tank again, a simple recric system, is there a way I can tie the outlet BC to the Inlet BC.
Eg If I take out 6000l/hr through the outlet, how can I specify the inlet to be a function of the outlet velocity / mass flow rate etc? Thanks |
May 22, 2007, 03:23 |
Re: recirc tank, inlet outlet conditions
On the run you can calculate the massflow through the outlet: massFlow@Outlet.
This can be used to specify the massflow through the inlet. Regs, Gert-Jan www.bunova.nl |
How to set pulsating inlet boundary conditions with a very high frequency | Ton | CFX | 10 | March 22, 2012 16:57 |
total pressure boundary problem ==> flow from outlet to inlet!! | mrshb4 | OpenFOAM | 0 | November 20, 2010 12:41 |
Outlet conditions in BuoyantFoam | jont | OpenFOAM Running, Solving & CFD | 2 | October 15, 2007 07:55 |
Periodic BC on Inlet and Outlet of a Duct | Steve | CFX | 2 | August 8, 2005 12:03 |
Inlet and Outlet Boundary conditions for LES | Jan Ramboer | Main CFD Forum | 12 | August 6, 1999 22:00 |
