November 18, 2021, 06:35 |
Fluent Meshing poly-hexcore meshes for CFX
Stuart
Rep Power: 26 |
Recently been considering to stop using ANSYS Meshing and instead use Fluent Meshing because of the recent poly-hexcore capability, which has the option "Avoid 1:8 Cell Jump in Hexcore" to avoid the hanging nodes which CFX cannot deal with. I see this now as the best meshing method: robustness of tetra/prism meshing for complex geometries with the benefit of cubic volume elements instead of tetra elements away from walls, and all with a lower element quantity.
Just curious if others have been using Fluent Meshing poly-hexcore for CFX simulations. As a long time CFX user (very novice Fluent user) I find Fluent confusing with some things that it does, unlike easy to use CFX. But ideally I would do everything in Fluent, but I have questions about Fluent that I cannot get answers for. |
November 18, 2021, 09:33 |
Gert-Jan
Rep Power: 27 |
No I have never used this. I tend to create an ICEM mesh and convert tets in the volume into a hex elements, to end up with the same kind of mesh.
Nevertheless, your query makes me curious. Do you mean that it is possible to import cutcell mesh from fluent into CFX, by using an option "Avoid 1:8 Cell Jump in Hexcore"? |
November 18, 2021, 09:49 |
Stuart
Rep Power: 26 |
I have been looking more and more into switching to Fluent Meshing for my CFX simulations.
Not sure about importing cut-cell meshes. But rather making poly-hexcore meshes from fresh in Fluent Meshing using this option to put buffer(?) layers of polyhedra since CFX does not work with hanging nodes in the octree arrangement. I was just curious if other CFX users had used Fluent Meshing with this mosaic technology, which looks great, to get away from the tetra/prism meshes of ANSYS Meshing. I stopped using ICEM ages ago because of the stagnant GUI, and it appears to being taken over by SpaceClaim Interactive Meshing (which I have avoided due to the errors I get when trying it, plus lack of tutorials). |
Fluent Meshing 2020R1 | wali | FLUENT | 5 | December 1, 2020 15:18 |
Fluent Meshing Mode | elochana | FLUENT | 1 | November 24, 2020 02:34 |
[ANSYS Meshing] Need help optimizing my Fluent Meshing Workflow | DL598 | ANSYS Meshing & Geometry | 0 | April 21, 2020 12:57 |
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench | aarvay | ANSYS Meshing & Geometry | 11 | January 12, 2017 12:51 |
Fluent meshing | ferroburak | FLUENT | 2 | October 28, 2014 00:50 |
