Merging mesh elements in ICEM
Old   May 9, 2007, 11:26
Default Merging mesh elements in ICEM
Felix
I would like to know if it is possible in ICEM CFD to merge some mesh elements.
I have a structured 2D mesh (no thickness yet) with low Y+ values and I would like to blend the first few elements normal to the wall to increase the Y+ without changing the mesh in the core flow.
Does anyone know if there is any way this can be done without re-creating blocks, re-assigning edges, etc... ?
Thanks !
Felix
Old   May 9, 2007, 11:33
Default Re: Merging mesh elements in ICEM
myron
Under Edit Mesh > Merge Nodes you can do node merging - but I'm not sure you can pick more than 2 nodes at a time - so what you want to do may be quite tedious... It might be faster to delete the extra elements - then just merge the outer node with the inner node.
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
